G'day from Down Under
Twitchy
Post by Twitchy »
Hello from Perth, Western Australia! I joined here a while ago doing pre purchase research, now I am happy to return an owner. In the absence of a paint code, I will assume its Italian Red, 2006 VTR1000 with Jardine RT-1 high mount cans, K&N filter and jetted accordingly. It has done 130 kms in 2 years, the clutch fluid had turned to a gel like sludge, and the brake fluid not much better. Henceforth I have decided to pull the carbs off to make sure float bowls and jets are not gummed up.
This forum has been a huge help so far, and I'm sure will continue to be. Hopefully I can contribute in the future.
06 VTR1000F; bits by Jack Flash, Erik Marquez & Jamie Daugherty. SP/954 front and SP2 rear in the works.
Build thread; http://vtr1000.org/phpBB3/viewtopic.php?f=41&t=36638
Re: G'day from Down Under
A very nice looking bike 8)
A good idea to go through things seeing as the clutch and brake fluid are in that state.
Welcome aboard from down under :thumbup:
macdee
Post by macdee »
Hello and welcome mate
welcome along sir. nice looking storm you have. good luck with it
Twitchy
Post by Twitchy »
Thanks guys. Here's a photo of the clutch window when I bought the bike;
I also put a post up in the 'Starting engine' thread about the brass replacement fitting on the choke cable (starter valve). I broke 1 on disassembly. I think I need to have made 10 posts to be able to PM gl_s_r.
50 posts lol .
Welcome back
Lube, no lube, it's your choice .
Nice looking bike. Welcome to the forum as an active owner :thumbup:
Salty Dog
Post by Salty Dog »
G'day twitchy, from the other end of the Nullabor.
We also share the same colour bike :)
3 out of 5 people are not the other 2.
G'day get that brake and clutch fluid flushed through and changed it's disgusting :eek2 :eek2 straight forward common DOT 4 fluid is what you want.
http://www.vtr1000.org/phpBB3/viewtopic ... 98#p117435
http://www.vtr1000.org/phpBB3/viewtopic ... ing+brakes
Welcome to the forum :beer:
Twitchy
Post by Twitchy »
Hey guys, thanks! Got all the little stickers off now so looks even better! Need to get a pic but its on a stand in the shed doing the carbs and ccts at the moment. Not licensed to ride it, so having it on a stand helps remove temptation.....
Big_Jim59
Post by Big_Jim59 »
Twitchy wrote:Thanks guys. Here's a photo of the clutch window when I bought the bike;Image
Welcome. Do not trust what the sight glass shows. Almost all of Honda's fluid sight glasses are yellow and fogged up. I had a buddy that devised a method of of replacing the sight glass with a wrist watch crystal and super glue. It worked but I never cared enough to try it.
Everyone breaks those paper mache choke brackets.
Twitchy
Post by Twitchy »
The window is not yellowed, but full of gunk. That reservoir window opened up to this;
So I tend to trust whats in the window!
