Cylinder heads - interchangeable???
BrianC
Post by BrianC »
Interesting question here - is it possible to modify a rear head to be a front one ?
Is it as simple as blanking off the hole for the rear cct adjuster and opening up the blanked one? If that makes sense !!!!!
Brian
Re: Cylinder heads - interchangeable???
BrianC wrote:Interesting question here - is it possible to modify a rear head to be a front one ?
Brian
Sort of but you'd need a milling machine to do it...
BrianC
Post by BrianC »
Is that to mill out the blanked cct orifice?
Reason i ask is that the spare engine i picked up today looks like this has been done
Would photos help ?
Brian
bsabloke
Post by bsabloke »
I believe rob dehoo http://www.exausist.com has done one of these. Maybe check with him for details :thumbup:
BrianC wrote:Is that to mill out the blanked cct orifice?
Would photos help ?
Brian
Yes exactly to mill out the blanked CCT orifice.
A photo could help, but seeing as the original CCT orifice would need to be blanked off, can you not determine from that if it has been done to your spare engine or not :?:
BrianC
Post by BrianC »
Hia chris
Yes the original has been blanked so it looks like a rear has been used - which is no prob
Brian
Varastorm
Post by Varastorm »
BrianC wrote:Yes the original has been blanked so it looks like a rear has been used - which is no prob
Hi Brian, Sounds good, have you any photo's?
Thanks in advance :thumbup:
VTRDaz
Post by VTRDaz »
Think my recently aquired vtr has had a rear head on't front too? I've got a spare engine and the front head on it had no blanking cover over what would be the tensioner hole should it be on the rear, but the engine in the bike has been blanked....... 8O It has had the manual tensioners etc done years ago as I've receipt from the work being done, but no bill for a head ?? I did wonder why it was different, Oh I dunno, I'm not going to worry and just going to use it :thumbup:
