Speedo not working
eamonn
Speedo not working
Post by eamonn »
Hello, Changed dash lights and now speedo not working, trip meter works ok, have checked connector blocks they seem OK, any ideas, Its the early analog dash, thanks
Re: Speedo not working
Have you checked connectors at both ends of the speedo sensor cable? Nr rear CCT and going into loom nr battery.
The can fail after a time normally showing intermittent erratic readings before dying completely.
As you've fiddled with back of speedo then something sounds like it's not connected back correctly in the console dept.
