Hello all. I know this has been asked many many times before but I can't find the threads on here so I have to ask again...sorry
Not bought a chain and sprocket for a bike before so looking for a steer on a good quality chain and sprocket. Looked on ebay and there are huge numbers and half are probably made of cheese so thought I would ask on here. In amongst the mickey taking I am sure someone will give me top advice
Chain and Sprocket - yes again!!!
Re: Chain and Sprocket - yes again!!!
DID chain and sprocket kit is the best option.
(Disclaimer............ that is only MY opinion)
TIP; Never take a sleeping pill and laxative on the same night
http://morrisonbhp.net/
- TheGingerBeardMan
Plus 1 for what Hallie said - "D.I.D" all the way! A well tried and proven, reliable chain.
This is what I use:
DID X Ring Gold chain and standard teeth front and rear sprocket kit. (Available on eBay from bikextremeUK, which is C&J Wilson (Uphall Ltd) in Edinburgh, Scotland).
£99.95 for the kit, and FREE P&P - you probably won't find this kit much cheaper! (To buy just the 102 link DID50VXGB chain will cost about 80 quid)
Link to website: Gold DID X-ring Chain and Sprocket Kit HONDA VTR1000 FIRESTORM 1997 - 2005
The X ring chain has different shaped O ring inside (Usually, you get "O" ring chains, but the rubber rings in this chain are X shaped - to hold the chain lube better and last longer.)
Front Sprocket: 16 Tooth
Rear Sprocket: 41 Tooth
Chain: DID50VXGB - 102 Links (Comes with soft rivet link).
JUST the chain is gold - the sprockets are standard steel, and will more likely be made by "JS"
This is what I use:
Last edited by TheGingerBeardMan on Mon Aug 17, 2015 12:49 pm, edited 5 times in total.
TAX: 1st March 2017
MOT: 16th March 2017
INS: 14th March 2017
TAX: 1st March 2017
- agentpineapple
I use a heavy duty d.i.d chain, sprockets all seem to be of decent quality, if iirc the d.i.d chain is a zvm, i'll have to check.
seems to be more that up for the job.
- alanfjones1411
D.I.D gold with standard tooth sprockets every time
Thanks gents! Time to spend some money.
Buy a cheap chain and you will pay twice as it will last half as long, if not less, than a better quality known branded more expensive chain. You can't go go wrong with DID.
