I haven't checked in for while. But the VTR is going well. Getting to know it and doing plenty of riding.
When I parked at work this morning I had a coolant leak down the left of the engine, about 1/3 cup in total including the coolant blown back on the swing arm and stand. Done a search and found it is often a number of things. Reservoir tank, leaky hose, dodgy clamp. There was still coolant in the tank and I topped it up the line.
Went for a ride, stopped multiple times to check and the bloody leak has taken up again! Bit hard to find a leak that isn't there anymore!
I can tell that it has been happening for some time due to the coolant streaks on the flywheel cover (been wondering what they were)
My hunch is that one of the large hoses on the thermostat is perished... Time will tell.. Will pull the tank and fairings tonight and give the whole cooling system the once over.
Anything else I should look out for cooling system wise?
Also discovered the clutch cylinder is leaking, I will be removing it to clean and re seal it. I vaguely remember reading to tie the lever back before removing the cylinder....is that correct?
