problem removing the front axel bolt
i'm having a bit of a mare.
I've decided to put better brakes on my bike, so I've sold my old set-up, wavy discs, sp2 calipers and master, asv levers and so on, so today I try to remove them from the bike, the first issue is the lack of decent tools, what an utter pta it is without good tools.
the fork pinch bolts were on to tight, but I got them off, the calipers were easy, as was the brake mc and lever.
but the major issue is the front wheel spindle bolt, there's some play in the 22mm socket i'm using, which isn't helping, I assume it's a 22mm socket that I need, as a 21mm is just too small.
no matter what I do I can't get the axel bolt to budge, I've even used a scaffold pole on the end of a 1/2 ratchet for extra leverage, but because of the slight play in the socket it just won't undo.
I have a theory as to why this might be, when carl knocked me off a couple of months ago, the axel bolt did have a build up off what seemed like white powder stuck to one of it's sides, I took a screw driver to remove it, but i'm thinking the bolt/axel may have been damaged in the accident, maybe even slightly bent, hence not being able to undo it.
so first am I right in using a 22mm socket.
and secondly has anyone got any tips on how to undo the axel bolt.
should I be putting a screw driver threw through the other end of the axel and counter turning it it help release the bolt at the other end?
I seem to think that was needed when re-attaching the wheel, but it's been a while since I've removed a front wheel.
helpful suggestions welcome, mac you can do one....... :lol: :lol: :lol: :lol: :lol: :lol: :lol:
popkat
Re: problem removing the front axel bolt
Post by popkat »
Yes it is a 22mm socket.
pinch bolts should be tight on the other side so the spindle doesn't spin.
get a better fitting socket would help, they must have motor factors in Spain ?
counter clockwise just incase your tightening it by mistake
Where's Carl when you need him
lloydie wrote:Where's Carl when you need him
I think it's his fault for this happening in the first place, he should do the decent thing and fly out here and fix it, well he could if he had a valid passport.....doh!!!
:lol: :lol: :lol:
darkember
Post by darkember »
If it was bent then the wheel would not spin true very much doubt that's the case.
Stop buying cheap Chinese tools. :lol: :lol:
bigtwinthing
Post by bigtwinthing »
have you tried "Putting some weight on it" :lol: .Good 6 point socket and a breaker bar Marty.
Stephan
Post by Stephan »
hammer and combination wrench (use ring side on bolt) should solve it. If you find 22mm near to you.
Lefty Loosey, Tighty Righty :thumbup:
Get rough with it. A big bar and a bash should give it the shock it needs :D
carmanbikes
Post by carmanbikes »
I got a electric impact wrench from machine mart and its great for rusted or tight bolts I got it to do the flywheel mod :thumbup:
Ckennedy
Post by Ckennedy »
I could always fly over with my snap on electric impact gun :wink: :wink:
Sent from my SM-A300FU using Tapatalk
I wish I had those tools, i'm waiting for a friend to arrive back from the uk, he should be here on the 15th, he's a retired engineer, he should have some decent tools for me to borrow... :thumbup:
i'm still pissed off tho, because even with the shabby tools I have, it should have budged, even when my 19st body building brother had a go(using the scaffold pole for extra leverage) it still didn't budge... :(
i've got until the 17th to get the blasted thing off... :x
Ckennedy
Post by Ckennedy »
Best of luck mate. Hope to get it off.
Ckennedy wrote:Best of luck mate. Hope to get it off.
I hope so too..... :lol: :lol: :lol:
i'll let you know mate.... :thumbup:
lumpyv
Post by lumpyv »
try a sharp tape from the side ,just one mind, might just loosen the threads a bit ( think like how an impact driver works ) :thumbup:
macdee
Post by macdee »
What about ice freeze the bugger then hit it with boiling water
