brake lever pulses
Steve97
brake lever pulses
Post by Steve97 »
Cant seem to sort this, have tried
calipers inc pistons
discs
head stock bearing
bled the system endlessly
master cyl seal kit
have even put different forks on,
all to no avail
your thoughts are appreciated
Re: brake lever pulses
Steve97 wrote:Cant seem to sort this, have tried
discs
head stock bearing
master cyl seal kit
all to no avail
Disc bobbins :?
Steve97
Post by Steve97 »
Done !
No difference
Varastorm
Post by Varastorm »
I take it you've tried swapping all the mentioned parts & it still pulses at the leaver?
Sounds odd that it's still doing it, but if you still feels pulsating my next step would be to get hold of a DTI (clock dial gauge) & start measuring things up :thumbup:
You can try cleaning the bobbins on the discs like Watty mentions.
[youtube][/youtube]
Hope this sorts it. But to me, it sounds like classic warped disc symptoms :thumbup:
Steve97
Post by Steve97 »
Had the wheel off and rigged up on a balancer for wheels, the discs fly straight, if a little thin at just under 4mm
Cadbury64
Post by Cadbury64 »
Just as a slightly random suggestion, how about undoing one disc, rotating it 180 degrees and bolting it back up? That way if there is some sort of synchronisation between the discs now that causes pulsing, you might eliminate it. No idea if that would work, but it won't cost anything.
Front tyre!?
Steve97
Post by Steve97 »
Watty wrote:Front tyre!?
Its new, and have checked it over
Steve97
Post by Steve97 »
Cadbury64 wrote:Just as a slightly random suggestion, how about undoing one disc, rotating it 180 degrees and bolting it back up? That way if there is some sort of synchronisation between the discs now that causes pulsing, you might eliminate it. No idea if that would work, but it won't cost anything.
Will try this tonight !
Steve97 wrote:Had the wheel off and rigged up on a balancer for wheels, the discs fly straight, if a little thin at just under 4mm
Personally I'd say checking the front wheel and discs for run out in the bikes forks would be best, after all that's where they will be running when on the bike :wink: Remove the brake calipers or pads and front mudguard to do this, I attached a piece of wire to the fork leg covered in insulation tape so it didn't scratch anything when you spin the wheel. If you have a dial-gauge that would be even better than using a piece of wire.
Have you checked there's no play in the front wheel bearings by hold the wheel at 180* with each hand and rocking it :?:
I'm assuming the front wheel spindle is straight :?:
Running the disc's off-set is worth a try, as Cadbury64 suggested,
Good luck,
Steve97
Post by Steve97 »
Hi Chris
Yep already done all that buddy,
I'll whip the discs off tonight and reseat them
bazzashadow
Post by bazzashadow »
have you painted your wheels?
Steve97
Post by Steve97 »
bazzashadow wrote:have you painted your wheels?
Nope
darkember
Post by darkember »
If everything is square and true. And you can be sure of that then it leads to a fluid issue. What system are you using?? Standard with splitter over the mudguard or race setup with singles to each caliper?? If using the splitter it could have an airlock in it..
bazzashadow
Nope
just wondered
I had mine painted and then scrapped the paint off were the disc bolts on so it had no paint squashed between it
