Electrics: bodge or replace
Stripped the knackered alarm off my rear loom yesterday which now needs to go back together.
The alarm wirers were all soldered onto the various wires so I cut them off close to the original wire as I could. Can I get away with bodging the exposed wires with shrink wrap and insulation tape or should I strip them all out and replace completely?
Re: Electrics: bodge or replace
Tidy them up and make safe ,
It'll be fine
decent bullet connectors and do the job right the once..it will come back to haunt you if you dont.
lloydie wrote:Tidy them up and make safe ,
It'll be fine
fabiostar wrote:decent bullet connectors and do the job right the once..it will come back to haunt you if you dont.
Only one wire is actually split which I will have to use connectors. The rest are intact but had the insulation stripped off.
bigtwinthing
Post by bigtwinthing »
wire them into a chocolate block, then seal with some waterproof grease etc and cover with heat shrink don't burn the grease off .
Or just sellotape them and never ride in the rain, or take it through a car wash for a bet.
No, I wouldn't either but back in the day a mate sellotaped the wiring on his BSA 650 Flash and then took it through the car wash for a bet, it never ran again but he won his £5 bet......
I can't see the point in cutting wires which are not already cut if you can get heat shrink sleeving over the exposed bits,
StuartWags
Post by StuartWags »
solder and shrink wrap
Sir-knob-head
Post by Sir-knob-head »
I have a loom untouched. Maybe we could trade them. As I need to cut mine down. I can trace them back and make good
Just an offer
Idiots exist everywhere
Doesn't mean you have to argue with them
Live to ride. Ride to live
