Swingarm linkage plate problems
KermitLeFrog
Post by KermitLeFrog »
I can't shift the bolt that attaches the linkage plate to the swingarm. The nut is off but the bolt itself won't move. I've given it a tap on the threaded end (with the nut screwed on a few threads) and I've tried turning it from the allen head end but it feels solid.
I'm assuming it is a bolt and only held together with the nut on the end and not screwed into the swingarm as well.
Do I just use a kin great hammer? I've got a butane torch but don't really want to use it.
Suggestions would be appreciated,
kind regards
worried of Hexham.
Re: Swingarm linkage plate problems
Heat , large persuader, and plus gas are your friends here. :thumbup:
KermitLeFrog
Watty wrote:Heat , large persuader, and plus gas are your friends here. :thumbup:
OK. Thanks!
carmanbikes
Post by carmanbikes »
I used an impact gun just wizzed it out :thumbup:
KermitLeFrog
carmanbikes wrote:I used an impact gun just wizzed it out :thumbup:
I'm assuming the bolt just pushes out. It dosn't need to be unscrewed (once the nut is off)?
KermitLeFrog
WD40 applied. I'm going for a dog walk. Will try again when I get back.
Correct , it's a push fit .
Heat the swing arm up and tw@ it a few times
macdee
Post by macdee »
lube
heat
bate the fcuk out of it :thumbup:
macdee wrote:lube
heat
we still talking about a swingarm or a wife :wave:
KermitLeFrog wrote:WD40 applied. I'm going for a dog walk. Will try again when I get back.
Contrary to popular belief WD40 is not a penetrating oil!
fabiostar wrote:
macdee wrote:lube
heat
Both work [THUMBS UP SIGN]
KermitLeFrog
Of the 30 odd cans in the shed, not one is PlusGas (or similar). It'll have to do....
Twatting soon! Stanley 20oz shuttering hammer first, before I get out the enginering hammers.
KermitLeFrog
It moved! I now have a mouldy shock in hand. I took the top shock mount nut off and dropped the lot down through the swingarm.
That's enough for today.
Good work. Quite often you just mushroom the end of the bolt and then it won't go through anyway.....The trick is to grease with copper grease on installation, then it comes out easy.
