caliper seals
caliper seals
ok so iv a nice set of fireblade front brakes to put on. stripped and cleaned but heres the problem!!. i need the seals that fit between the two halves of the calipers. one per caliper but can i find a set. i dont wana buy a whole seal kit just to get these two we rubber seals ffs :redface .
can they be got separate? has anybody got any?
cheers
the seals i have seem to have ballooned up and are twice the size they used to be..
Re: caliper seals
Can you not take them from the callipers your replacing or are they the ones that have swelled up ?
Re: caliper seals
See here for bikes that use the same part...
http://www.ronayers.com/oemparts/p/hond ... seal-joint
See here to purchace said part...
http://www.cmsnl.com/honda-vtr1000f-fir ... mNper9QLvQ
Re: caliper seals
jesus im even more confussed now lol... that list mac has the vtr and fireblade using the same seals?? .
iv my standard calipers which i dont wana pull apart incase i cant get these bitches of fireblade ones to bleed. which iv been trying to do for about two months on and off now lol..lord only knows how but the seals look twice the size they should be :oops: .
mmm the picture in the second link looks just like what i have.....
Re: caliper seals
http://www.bike-parts-honda.com find the relevant year for your Fireblade model and locate the front brake microfiche and Honda part no.
Here's the Firestorm page for reference:
http://www.bike-parts-honda.com/moto-ho ... 11510.html
Bookmark the page for future reference and use the Honda part no in the Ron Ayers search for common models usage which will tell you what other Honda it may have been used for. Which Mac has kindly done for you and the list shows the seal is common on a multitude of Honda front brakes covering 1990–2015.
Then that opens up possibilities in googling suppliers https://www.google.co.uk/?gws_rd=ssl#ne ... 03-MR7-006 or seeing if its listed on eBay > http://www.ebay.co.uk/itm/VFR-RC30-CBR- ... OSw7aBVBZL~ - or just copy and paste the Honda Part no into David SIlvers 'find by part number' > https://www.davidsilverspares.co.uk/par ... rt-number/
Re: caliper seals
Wicky wrote:http://www.bike-parts-honda.com find the relevant year for your Fireblade model and locate the front brake microfiche and Honda part no.
Then that opens up possibilities in googling suppliers or seeing if its listed on eBay - or just copy and paste the Honda Part no into David SIlvers 'find by part number' > https://www.davidsilverspares.co.uk/par ... rt-number/
ay that list mac put up seems to show pretty much every honda in the world uses the same caliper joint seal... which is what came outa the calipers? il have a look at those sires and see if i can make sense of them before they end up in a bin lol
Re: caliper seals
While you've got the calipers apart to the extent of splitting them then it'd be a good opportunity to also refurbish & replace the piston seals as well - and it looks you get the internal seals as well.
http://www.ebay.co.uk/itm/Honda-CBR900- ... 1206730299
If you are having problems bleeding them you might also want to consider getting new bleed nipples / copper banjo washers all round.
Re: caliper seals
Wicky wrote:While you've got the calipers apart to the extent of splitting them then it'd be a good opportunity to also refurbish & replace the piston seals as well - and it looks you get the internal seals as well.
happy days found the number i needed and ordered them from silvers... they have been fully rebuilt just before i got them. i only split them to clean them and only noticed today when i was putting them back together the seal joints appeared twice the size they used to be?. iv new bangos and washers all ready to go :thumbup: :thumbup:
Re: caliper seals
Silvers get most of there stock from the place I listed CMSNL, then they add there bit on top + have top $ shipping rates to add on as well.
Same part, more expence from DS...
I duno you try & help some people... :roll:
Re: caliper seals
fabiostar wrote:jesus im even more confussed now lol... that list mac has the vtr and fireblade using the same seals?? .
Lot's of parts are interchangeable between bikes, saves money for the construtors. The callipers may be different in lots of ways but some parts will be the same on both...The joining seal, pad pin, calliper bolts, the cap screw & the bleed nipple. VTR only uses 1 pin & cap but they are still the same.
Re: caliper seals
ay mac i had a good look at those lists and as you say pretty much everything is used on every model..
lets just see when the seals arrive if these ..god dam wombles calipers will bleed once and for all :Argue 1: :oops:
Re: caliper seals
the calipers in question are my old 1998 blade jobbies which I didn't end up using, they had been fully checked over by our resident brake guru of Essex, you might know him as the ginger bearded one...... :lol: :lol: :lol:
looking forward to you fitting the calipers Fabio, let us know how you get on buddy..... :thumbup:
Re: caliper seals
agentpineapple wrote:the calipers in question are my old 1998 blade jobbies which I didn't end up using, they had been fully checked over by our resident brake guru of Essex, you might know him as the ginger bearded one...... :lol: :lol: :lol:
they are indeedy the very calipers. iv stripped of the blue paint and they have come up like a new set of calipers :clap: . cant wait to get them on.
only this time il take my time lol... as for the joint seals, I checked them again today and get this. the seals have went back to normal size???? not to worry iv a new set on the way :thumbup:
Re: caliper seals
I've got a set of them seals drying out .
I left them in brake cleaner to long and they went the size of polo mints !!!
Re: caliper seals
can't go wrong with new seals..... :thumbup:
they are a nice set of calipers, but iirc I sold them way to cheaply..... :lol: :lol: :lol: :wink: :(
