Brakes
Brakes
ok got my blade calipers on. very nice. i have the matching master to go with them but iv fitted vfr800 bars and the master just wont sit far enough up the bars before it hits the bar mount?.. so to stop me having to remove a "v" outa the bar mount end has anybody used blade calipers with a standard storm master?
or has anybody had the same fitting issues space wise and got around the problem?
cheers
Re: Brakes
SORTED< after a million different things, bars dont hit fairing,or tank and master just about sits where i want it :eek2 . simple things can look better after a beer :D
artee
Re: Brakes
Post by artee »
What did you do?
Roger
Re: Brakes
artee wrote:What did you do?
Roger
As Roger said :)
Re: Brakes
Usually you have to re-angle the banjos on the MC, as they foul the fork leg or the top yoke clamp bolt.
Re: Brakes
tony.mon wrote:Usually you have to re-angle the banjos on the MC, as they foul the fork leg or the top yoke clamp bolt.
spot on :thumbup: i also filled a little bit on the leading face of the clipon to allow the master cylinder to slid up far enough so i could get my switch and throttle tube on. bonus is you cant even see it because the master slipped up enough to cover it :thumbup:
Cadbury64
Re: Brakes
Post by Cadbury64 »
I took Mr Dremel to the pegs on the master cylinder that stop the hose fitting being rotated to a more sensible angle.
CBR954 brakes are lovely! I did look at swapping the reservoir off the VTR master onto the CBR master as the latter spoils the view of some of the instrument lights, but they're actually the same piece, the reservoir mount on the 954 master cylinder is further inboard than the VTR so swapping parts won't help.
