Rusty Tank
Rusty Tank
Pulled the tank off today and the glorious yellow colour is complimented by the red rust on the inside not! Anybody done the old tank seal thingy. Hints tips or just strike a match.
- bigtwinthing
Re: Rusty Tank
Richard wrote:Pulled the tank off today and the glorious yellow colour is complimented by the red rust on the inside not! Anybody done the old tank seal thingy. Hints tips or just strike a match.
its Yellow, get the matches
Re: Rusty Tank
Jeez, what a combination, pus yellow and rust red. Probably best to follow the advice given and use a box of swan vesta!!!!
Re: Rusty Tank
He! He! another pyromaniac, just like me. Lend us a match!
- bigtwinthing
Re: Rusty Tank
Richard wrote:He! He! another pyromaniac, just like me. Lend us a match!
as its yellow do you want petrol too
- agentpineapple
Re: Rusty Tank
I was thinking about Popkat too, not sure how he got on though, he was discussing the use of "Phosphoric acid" that 954luca used.
See link here:-
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=35805
can you believe that Marty, that was back in January this year
it didn't feel that long ago,
See link here:-
Re: Rusty Tank
Thanks sirch345, much appreciated. I have found a thing on the Real Classics website which use all that sh1t and think I will give that a crack. Breaking Bad here I come
Re: Rusty Tank
Just be careful of the paint work. It would be interesting to hear how Popkat got on with the Phosphoric acid, that is if he did use it in the endRichard wrote:Thanks sirch345, much appreciated. I have found a thing on the Real Classics website which use all that sh1t and think I will give that a crack. Breaking Bad here I come
Re: Rusty Tank
I used phosphoric acid from this place http://www.ebay.co.uk/itm/25-Litre-Phos ... SwBahVSdOd this one is 25ltr but I ordered just a 5 litre bottle, they've not got it listed at the moment but worth asking them if they have some.
I also got a cork bung from here which was 100mm iirc http://www.ebay.co.uk/usr/gblaboratorye ... 2749.l2754 again it's not currently listed but give them a shout they may have one.
My tank had surface rust not thick rust, it was still getting through to the carbs though. I also got a new filter as my one came out damaged, they aren't cheap (about £30) so save yours if you can. I drained the tank and once empty I left it for any last bits of fuel to evaporate. then I cut the cork to make 2 bungs, I bunged the filler cap and fuel filter/tap holes, I cut the bungs close to size then put them on the grinder to make the shape, this bit is a bit messy and dusty so wear a mask. if you have loose rust in the tank put some water in and sleush (is that a word ?) it around to get as much out as possible, then when empty put you bungs in and seal them with some silicone sealer. Leave over night to go off.. the next thing I did was to de solder the wires off a spare fuel sender unit, this is the hole I put the phosphoric acid in, I might not have needed to do it but as I had a spare I didn't want to risk messing up my fuel sender. you could just de solder then re solder after it's only two wires, I also unbolted the plunger so all I had was a plate with large rubber O ring.
Tank will now be ready.
I poured 4 litres of water in the tank.. THIS BIT IS IMPORTANT, ADD THE ACID TO THE WATER NOT THE OTHER WAY ROUND !!!!!.. http://antoine.frostburg.edu/chem/senes ... acid.shtml
then I slowly added the 5 litres of acid to the water.
Bolt on the fuel sender plate.. if you secured the bungs properly you will have no leaks, would be worth a quick leak test first with water if your not sure..
I first let it sit for about half hour then rotated onto it's side, then top then other side, I gave all sides/angles half hour then turned it upside down took the sender plate off and had a look, I think I gave it about another quarter of an hour on each side then was happy with the result.. just keep checking but I don't think it needs hours and hours, well mine didn't... remember the acid I used was 81% before diluting.
Next I removed the plate and drained back into the original bottle and two 2 litre plastic milk bottles. then took the tank outside put it on a couple of old sheets and hosed it out, spent about an hour doing it to make sure no traces of acid were left.. Note if you have a dirty path do it over that, the acid will clean it right up but it will notice (phosphoric is also concrete cleaner). once clean I drained the water out as best I could, dried tank off and put a hair dryer in the filler hole. it is important to fully dry the tank, although phosphoric leaves a fine coat mine had a couple of rust colour streaks next morning where I ran out of time to fully dry it, this was not rust just discolouration and very slight. Other than that my tank was like new inside, I was very pleased with the result.
I then put the tank back on the bike and filled right up with fuel, I wasn't using the bike straight away so I put super unleaded in as there's less or no ethanol, but you could fill with regular and add a fuel additive such as Forte Moto 1 and 2 to the fuel and give it a gentle shake to mix it in. even if you don't it worth using the stuff once a year as it does work well..
I have had no problems with my tank or the way the bike runs since I did this.
Lastly if your fuel tank is rusty take your carbs off and give them a good clean, there's guides on here for removing/refitting them, be careful with the chokes and don't mix the jets up.
Re: Rusty Tank
sirch345 wrote:Just be careful of the paint work. It would be interesting to hear how Popkat got on with the Phosphoric acid, that is if he did use it in the endRichard wrote:Thanks sirch345, much appreciated. I have found a thing on the Real Classics website which use all that sh1t and think I will give that a crack. Breaking Bad here I come![]()
Phosphoric is unlikely to damage your paint, it's used in foods but much weaker although if you get it on the paintwork wipe it off with a wet rag soon as... other treatments use sulphuric or muriatic acid which will damage you paint very quickly, also if tank is bad inside it will eat a hole making it scrap..
Another reason I used Phosphoric is it's water soluble so if you water it down a lot you can eventually tip it down the sink safely, it'll clean the drains too
I kept the phosphoric acid and still use it for rusty bolts on other bikes, if I filtered it off I could use it on another tank if I needed.
Re: Rusty Tank
Cheers guy's, here I come Walter White eat your heart out
- agentpineapple
Re: Rusty Tank
where did the year go chris........sirch345 wrote:I was thinking about Popkat too, not sure how he got on though, he was discussing the use of "Phosphoric acid" that 954luca used.
See link here:-
why is it when you are a child, it takes forever to reach adulthood, and then you hit a certain age and the years fly by so dammed fast....
Re: Rusty Tank
Popkat, thanks for the detailed posts on using Phosphoric acid
It must be something to do with the older you getagentpineapple wrote:where did the year go chris........sirch345 wrote:I was thinking about Popkat too, not sure how he got on though, he was discussing the use of "Phosphoric acid" that 954luca used.
See link here:-
Chris.![]()
Re: Rusty Tank
Popkat, could you do a new post with your instructions and put it up as a Knowledgebase sticky?
Tony
Tony
