seat lowering
seat lowering
hi all looking for advice on lowering seat height. not only old and grey but a bit of a short butt as well .my inside leg 29" thanks ken. i shall now brace myself ready for comments I am about to get for my inside leg measurement.
Re: seat lowering
You can get adjustable dog bones, or a shorter shock- Hagon will do one- or if you only need a small lowering, just have the seat reupholstered with thinner padding.
The bike's, not yours....
Re: seat lowering
thanks Tony, I think hagon shock will be a bit pricey but I will look into your other options thanks kentony.mon wrote:You can get adjustable dog bones, or a shorter shock- Hagon will do one- or if you only need a small lowering, just have the seat reupholstered with thinner padding.
Re: seat lowering
Theirs a bike being parted out as they say on the super hawk forum
Lowering links are next to be posted
Re: seat lowering
If you've not done so already, check that the previous owner has not fitted a spacer on the top shock mount to raise the rear end. If you have one it'll be between the top shock mount and the frame,
Re: seat lowering
If it's still got the original shocker then it's probably past its best anyway. Fit a Hagon and you'll be amazed how much better the rear suspension will be.baycat wrote:thanks Tony, I think hagon shock will be a bit pricey but I will look into your other options thanks kentony.mon wrote:You can get adjustable dog bones, or a shorter shock- Hagon will do one- or if you only need a small lowering, just have the seat reupholstered with thinner padding.
Re: seat lowering
id try the seat foam first. its the cheapest and if you change the dog bones to lower the rear the bike will handle like a wheelie bin
Re: seat lowering
It wheelie wheelie willfabiostar wrote:id try the seat foam first. its the cheapest and if you change the dog bones to lower the rear the bike will handle like a wheelie bin
- agentpineapple
Re: seat lowering
contact alastair of elsemade, he'll be able to lower your seat height but retain a good level of comfort.
Re: seat lowering
Watty wrote:It wheelie wheelie willfabiostar wrote:id try the seat foam first. its the cheapest and if you change the dog bones to lower the rear the bike will handle like a wheelie bin
Re: seat lowering
wear high heels ???
sorry il get my coat...........
Re: seat lowering
fabiostar wrote:wear high heels ???
can I borrow yours
Re: seat lowering
baycat wrote:fabiostar wrote:wear high heels ???
can I borrow yours
only if your bikes yellow
Re: seat lowering
+1 - he's a good guy and does a great job - sales@Elsemade.comagentpineapple wrote:contact alastair of elsemade, he'll be able to lower your seat height but retain a good level of comfort.
Re: seat lowering
If you need to keep your bike on the road, I have a seat base ready for recovering you can have.
