Handlebar conversion
Moderator: VTRDark
Pon
Post by Pon »
Hello, I'd like to change the clipons for bars so I'm after the full kit or maybe parts that I can cobble together? I have some 20mm clipon risers on at the mo' so they will be for sale once I get all the conversion parts together.
If at first you don't succeed - tools down and go for a ride.
Re: Handlebar conversion
iirc vfr bars will work, do a search for info, or someone will be along who knows more about it mate.
Yes the VFR bars do fit I had them on my yellow storm R.I.P. :(
Pon
Post by Pon »
Yeah but they are still clipon style, I want up and back more :Beer Popcorn:
Pon
Post by Pon »
Sod it, I'll bite the bullet and go for this kit http://www.bikermart.co.uk/proddetail.asp?prod=154-136
Without bars and bar ends and with a discount code for 10% off it's £215.95
I suppose I could recoup some dosh by selling the old clipons, brake lines and risers I already bought and fitted.
Anyone local who's good at carving up fairings with a dremel?
Dendrob
Post by Dendrob »
Pon wrote:Sod it, I'll bite the bullet and go for this kit http://www.bikermart.co.uk/proddetail.asp?prod=154-136
I assume this item bolts on top of the existing yoke?
it replaces the top yoke.
Dendrob
Post by Dendrob »
How does it clamp up? Where's the ignition key go?
Ay rite enough ??
Dendrob
Post by Dendrob »
fabiostar wrote:Ay rite enough ??
Methinks it bolts on top maybe. Via the stem nut?
Pon
Post by Pon »
It just fits on top, key stays where it is :)
ah nice one, cant say iv seen that before. get some pics up when you get so we can have a good look :thumbup:
Ant
Post by Ant »
Hello pon, I've got a set of the lsl mounts that clamp on to the forks if you're interested?
If it's broken; should it move? Yes: Use WD40 No: Use cable ties. Now it's fixed!
Pon
Post by Pon »
Ant wrote:Hello pon, I've got a set of the lsl mounts that clamp on to the forks if you're interested?
Hello Ant, I gone and bought the ABM kit. Thanks for the offer tho'
redpig
Post by redpig »
Hello Ant, you on about the clamps which don't replace the yoke?
ook
