The tank bag is 370mm long x 330mm wide x 150mm deep. It has a main compartment, 2 zipped side pockets, internal slip pocket and zipped map pocket (clear lid). It has all straps and rain cover that came with it.
The tail pack is roughly 360mm square and 250mm deep. It has built in bungee straps which have a clip over cover so you don't fishhook folk when walking through crowds! Zip pocket at front of the bag and a zipped pocket on the rear containing rucksack type straps. Zip up lid has a zipped pocket on the inside. I changed the original carry strap for a Dell laptop case strap as the original had weak plastic catches. Comes with rain cover and additional bungee set.
After £30 for the pair plus post.
