Throttle cable(s) ?
Stepkevh
Throttle cable(s) ?
Post by Stepkevh »
Was checking after some parts while i crossed an image about the throttle.
Does a Storm have 1 or 2 throttle cables ?
I only have 1 on mine but according to the picture there are 2 available (part #1 & #2) :?:
~ Imagination is only limited by your mind ~
Re: Throttle cable(s) ?
standard is 2 cables, one to pull open and one that pulls shut [incase springs fail].......... I have taken the return cable off mine after I fitted the quick action throttle, makes the pull lighter and also allows you to take out all the slack without the throttle being slow to close [as the 2 cables fight each other]
Stepkevh
Post by Stepkevh »
Ok, thx, good to know.
Even if there have to be 2 "original" i'll stick to my 1, it doesn't pull that "heavy" :)
