Air box lid off...
Remove the stacks, two captive screws each.
Stuff some rag/paper towl down the carb throats...
Remove the four screws that were hidden by the stacks from each carb throat...These are what hold the air box base to the carbs, these are also why you have stuffed the carb throats as you don't wanna be dropping them down the carbs...
Pull the base up & pop it off the four pipes underneath, have a look before you do to see what pipes & where they go back whaen you need to refit it.
Once removed you will reveal the carbs.
The chock cable runs from the left side of the frame goes to a splitter then two seperate cables run around the carbs & fix in on the right hand side, one to the front & one to the rear...The nuts they connect with are plastic & can snap quite easily...
As Popkat says just check to make sure they are both seated properly...
I have a spare if nessasary...
