Over head lifting.
StormingHonda
Over head lifting.
Post by StormingHonda »
Right it seems now that I will need to remove the engine from the Fireblade as it looks like the valve seals or some of the valve seals in the head may be leaking, I need something I cam suspends the bike with whilst I remove the engine, as aparently its impossible to remove the head whilst the engine is attached, so the swing arm needs to come off the bike, the only way I can think of do this is to suspend the bike from the sub frame and front engine whilst I take out the engine.
Any ideas or has someone got a set up I can see, I need to do this in my garage.
Mav617
Re: Over head lifting.
Post by Mav617 »
Got any beams/joists you can throw a ratchet strap over?
bald_pig
Post by bald_pig »
Ratchet strap over an RSJ, hooke on your pegs or frame :thumbup:
http://www.fireblades.org/forums/honda- ... dvice.html
or stepladders to suspend it if you can't hang it from rafters
[youtube][/youtube]
Removing engine in the garage. All process took 8 hours. This is fast forward version.
StormingHonda
Thanks for the ideas, the biggest problem is the swing arm is bolted onto the back of the engine, and its a braced custom swing arm so the shock is bolted to the swing arm to the linkage, so thats going to have to come off.
The wooden frame is a good idea.
