2 x Exhaust cams FS Sevenoaks, Kent £35 posted
Moderator: VTRDark
As you all know, the exhaust cam has slightly more lift than the inlet one, and so you can fit exhaust cams instead of the inlets.
It doesn't make a big difference, (it's less than 1mm) but every little helps, and is an easy job.
While you're there you can check the valve clearances.
Or, if you don't want to get your hands dirty, I can fit them for you and do the valve clearances, ride-in, ride-out, same day. You'll need to come to my gaff in Sevenoaks, though, 15 mins from J3 on the M25 if that helps, near Brands Hatch. A full major service can be done in the day if you bring oil and filters. I could also fit manual CCT's while we're there, if you haven't already done this.
It's my last set of exhaust cams, so best get a move on.....
