I think it should be understandable but want the coolant pipe that runs from the pump around the frame and then to the carbs... ?
Thanks muchly as always
Coolant pipe
Moderator: VTRDark
Coolant pipe
Re: Coolant pipe
Makes sense to me, any fuel line or vacuum pipe with the correct inside diameter will do for this, just cut it to the correct length. 8mm is the inside diameter.
However in keeping with the 'Wanted' forums rules, I have some unopened 7mm fuel line that is plenty long enough complete with clamps in its packaging.
Re: Coolant pipe
You coming to Maidstone soonish.?
You can drop by and collect one FOC
Re: Coolant pipe
I've got a set you can have if you want them mark
- agentpineapple
Re: Coolant pipe
standard hoses on marks bike, that just won't do......monkeymatt wrote:I've got a set you can have if you want them mark
Re: Coolant pipe
agentpineapple wrote:standard hoses on marks bike, that just won't do......monkeymatt wrote:I've got a set you can have if you want them mark
Got plenty of stainless braided hose to
