Clutch not working, Help needed
Just replaced the chain and sprockets on my FireStorm, when I came to fit the the clutch slave piston back into possition to my surprise the clutch doesn't work anymore the lever has very little resistance, I've checked the fluid and the movement of the piston, and all seems fine and before anyone asks, yes I have put the push rod back in, and the right way round.
I'm almost sure someone posted up on here a few weeks ago with the same problem, but I can't find the post, can anyone give me a bit of help here coz I'm totally baffled
Like what you do
Do what you like He who wonders isn't always lost
- StormyRob
Re: Clutch not working, Help needed
Sorry I will probably be no help here at all! However I was advised this would happen if you changed the sprocket without first pulling and holding the clutch lever against the bar. I could also be talking s@#t and apologies if I annoy!
Just bleed it Kev..& keep bleeding it...Did Bloo the other day inc total strip as new line going on...bled & bled it got nice feel at lever still not got proper clutch action...so bled it again & again....
Get Ad's on it I hear he can be a little bleeder...
Back fill it then start pump and release
Yes worse thing you can do IMO... ...the last thing you want is presure on the M/C when the cover is off...Take the lever off, even just leaving it on there is presure albit small on the M/C hence why the slave creeps out...StormyRob wrote:Sorry I will probably be no help here at all! However I was advised this would happen if you changed the sprocket without first pulling and holding the clutch lever against the bar. I could also be talking s@#t and apologies if I annoy!
Someone will be along in a min to say put a cramp or a zip tie on the slave to stop it coming out...fine cept when it's in the way of you doing what you want to do...Take the lever off...Simples...
- StormyRob
I'm guessing I just confused that with something else!!!
The slave pops out as there is a spring behind the piston pushing it out .MacV2 wrote:Yes worse thing you can do IMO... ...the last thing you want is presure on the M/C when the cover is off...Take the lever off, even just leaving it on there is presure albit small on the M/C hence why the slave creeps out...StormyRob wrote:Sorry I will probably be no help here at all! However I was advised this would happen if you changed the sprocket without first pulling and holding the clutch lever against the bar. I could also be talking s@#t and apologies if I annoy!
I always just gave it a good bleeding if I removed the slave
A good way of orienting it is to remove the larger alternator centre cap.
Then push that into the slave piston and cable tie it in place.
No need to bleed then.
That's what I do, it just releases that tiny bit of pressure on the slave cylinder,MacV2 wrote:Take the lever off...Simples...
Just re bled my clutch because when I went to rebuild the engine I didnt add enough was too dumb to realise the rubber boot was not supposed to be unrooled condom shaped but neat and rolled!
Anyway yeah bleed the heck out of it. youd be amazed how much air you get out after the lever gets good and hard!
My clutch fluid was dark and full of kugen afeter 2000 km
Hey MacV2, Adams not so little now, he's actually 6'-1''MacV2 wrote:Just bleed it Kev..& keep bleeding it
Got around to doing it today, and yes it was one hell of a bleeding effort, but finally got there in the end, all working fine again now.
Thanks to all that took the time to post up and help out
Like what you do
