cheers
Moderator: VTRDark
I'll have a look later in my Top Hat collection Rob...Thing is there are loads of different sizes on the bike...I'll give you a shout a bit later after I have had a rake & checked sizes...fabiostar wrote:have any of you good gents got a pair of top hats that fit into the front petrol tank mounts? i have the rubbers but missing the metal inners?
cheers
happy days Mac, i can trim the length.MacV2 wrote:Rob after a good rake...I dont have the correct ones that fit as should but I can sort you out some others...
The rim is a bit smaller, the tube is a bit longer, so would need trimming, they are the correct size to fit in the rubber & for the bolt to fit.
So if you trim them down as long as they are flush with the top of the rubber they will be OK...
Let me know if you want them & I'll stick 'em in the post...
OK Rob I'll get them off to you. Will be Monday now as missed last post...fabiostar wrote:happy days Mac, i can trim the length.MacV2 wrote:Rob after a good rake...I dont have the correct ones that fit as should but I can sort you out some others...
Let me know if you want them & I'll stick 'em in the post..., beer vouchers no problems
