Trying to press on with the rebuild of my storm after replacing the valves etc following a cct failure by the previous owner!!!
Got the cam covers back on this morning and tried to fit the carbs. - could i get thrm to slip into the collars. - no chance. Could get either one on but notvthe other - tried greasing the collars etc and still no go.
The collars are rock hard so there is no play to allow the carbs to slide on - is this normal that they are so hard?.
I have mow removed them from the cylinder heads and they will barely slip over the carbs .
Am i into buying new?
Also a quick question re routing of the rear choke cable - is it routed under the carb?
I had such plans for today !!!!
Thanks
Brian
help!!!!! Im stalled !!!!!
Re: help!!!!! Im stalled !!!!!
Get the hairdryer on them...Its still pretty cold today and the dryer should help them to become a little more supple.
it is normal.
bit of heat, bit of lube and a large chunk of brut force [like full body weight and an impact]
VTR1000F (Superhawk) Firestorm Service Manual PDF > http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=18025
Thanks chaps
Id got there before i came back on line. - lots of lube did the job !!!!
Luckily id routed the choke cable correctly!!!
Great help from this forum once again
Thanks chaps
Thanks chaps
Note to self
Read the bloody instructions !!!!!!!
Having struggled to fit the carbs i then realised i had forgotten to fit the plastic covers !!!!!
So off with the carbs, fit the covers then back on with the carbs.
Least i managed to also fit the oil cooler as well so progress is happening !!!!
Complete day with no work tomorrow so hopefully i can move things on a bit
I boil them then fit them while still warm and always use lube :-)AMCQ46 wrote:it is normal.
