10w-30 JASO?
Solarboy
10w-30 JASO?
Post by Solarboy »
Hi all,
I've been away from the VTR scene for many years and when I last had one I used to get it serviced at the local dealers. I've now bought a 29 year old Storm with 35k on her and thought I'd change the oil myself. I went to the local dealer and asked them fir oil and they sold me Castro 10w-30 JASO.
Now looking at the manual (should have done that first)! It looks like this oil is not suitable. I have had a read through the forum for advice but I am still unsure. Can anyone help, please!!
If we don't learn from our mistakes we are destin to repeat them
Solarboy
Re: 10w-30 JASO?
Post by Solarboy »
Sorry 20 year old not 29!!! DOH!
Re: 10w-30 JASO?
10w 40 is the recomended. Semi synth not fully synth.
Solarboy
Re: 10w-30 JASO?
Post by Solarboy »
MacV2 wrote:10w 40 is the recomended. Semi synth not fully synth.
Thanks for that. I wonder why a Honda dealership would sell me the 10w-30?
Stephan
Re: 10w-30 JASO?
Post by Stephan »
Because Honda started to use 10w30 instead of 10w40 few years ago and say it is applicable for older bikes too. I think you can use it, maybe it is better, but 10w40 is very well proven to use.
Solarboy
Re: 10w-30 JASO?
Post by Solarboy »
Then that's good enough for me. I'll swop it for 10w-40 semi. Cheers, James
VTR Phoenix
Re: 10w-30 JASO?
Post by VTR Phoenix »
it's just a thinner.oil, supposed to get to the head quicker on startup, performance engines use a 0 weight
jchesshyre
Re: 10w-30 JASO?
Post by jchesshyre »
I thought 10W30 and 10W40 are the same weight when cold (hence the 10) but 10W30 is thinner once warmed up, so not so good if you ride somewhere very hot but otherwise fine for these bikes?
Solarboy
Re: 10w-30 JASO?
Post by Solarboy »
Thanks guys, it will teach me to buy the oil and then look at the work shop manual! Lol I'll use the 10w40 and take the 30 back. I'd rather go with the manual and avoid a potential issue. This is my first post so all you help is really appreciated.
Stephan
Re: 10w-30 JASO?
Post by Stephan »
jchesshyre wrote:I thought 10W30 and 10W40 are the same weight when cold (hence the 10) but 10W30 is thinner once warmed up, so not so good if you ride somewhere very hot but otherwise fine for these bikes?
10w30 is thinner when engine is cold, see viscosity at 40 deg, however minimal pumping temperature is similar. For water cooled bikes, 10w30 should be ok at operating temperature. There is theory and some testing, that 10w30 is more robust under hard conditions, and keeps engine colder due to better flow. But as said, 10w40 is very well proven on bikes.
Re: 10w-30 JASO?
Welcome to the forum
jchesshyre
Re: 10w-30 JASO?
Stephan wrote:10w30 is thinner when engine is cold, see viscosity at 40 deg, however minimal pumping temperature is similar. ...
Right you are - should have done my research!
The OP shouldn't worry about using 10W30 unless he's riding in temps of 32ish degrees C or more - in the workshop manual Honda say:
Solarboy
Re: 10w-30 JASO?
Post by Solarboy »
No, just good old UK so should be fine apart from the two days of summer we might get!
Thanks again
Re: 10w-30 JASO?
Solarboy wrote:No, just good old UK so should be fine apart from the two days of summer we might get!
Thanks again
2 days of summer!! Love your optimism!! Oh and welcome aboard :thumbup:
Re: 10w-30 JASO?
i use 30 in colder weather and for the summer i use 40.. i doubt it makes much difference mind you.
