Branded lines
Solarboy
Branded lines
Post by Solarboy »
Hi All,
Probably a silly question but can you pinch branded brake lines with mowle grips in the same way you can rubber ones? Not sure if this will destroy the brade or inner? I want to service the calipers.
Thanks
If we don't learn from our mistakes we are destin to repeat them
Re: Branded lines
No.
And you shouldn't do it to rubber ones either.
Re: Branded lines
tony.mon wrote:No.
+1 .
Re: Branded lines
Surly a service to your brakes should include new fluid anyway ?
Just drain the the system & them remove the callipers...
Or buy a dry brake system like they use in Moto GP...
