Sprockets are obvious when they need changing, but the chain is another thing, I think it can be quite a tough one to judge for people like myself with very little knowledge. I also understand that its a good idea to replace the whole system, chain and sprockets.
I have checked my chain before a blast out on Wednesday and it was a little loose, so adjusted it. The manual says that when on the side stand there should be between 30-40mm play. But I have hight level link pipes and my chain hangs on it when On the stand, so I cant really get an acurate measurement, not sure if this is the case with standard pipes?
So sitting on the bike I tried to put as much weight as possible on the bike reaching down to make sure there is still some movement not putting to much strain on the chain. But with me sitting on the bike, how much play should be in the chain? Surely in general this will depend on the weight of the individual as to how much slack should be when the bike is on its side stand? Im a heavy lad, 18 1/2 stone so really the slack should be more than a 8 stone person?
Looking at the indicators on the side, my chain is still OK to use, however, I run a 43 sprocket on the rear, so surely that will use more chain thus making these adjuster marks redundant? Please correct me if I am wrong because I dont know.
Then with the bike on the side stand ive pulled the chain away from the rear sprocket and there is a little gap, what is the maximum movement you can have at this point between the chain and sprocket? My rear sprocket is in real good condition, only done about 4k miles. Front sprocket is also in very good condition.
I dont know how old my chain is, I have owned the bike for 5 years and have done about 8k, it looked pretty good when I bought it and have looked after it as I really dont want it snapping when pushing it.
Is there any length of time a chain is good for? And am I correct to say a chain is generally good for about 20k miles?
I have also read about 16 and 21 pin measurements but with the chain on the bike this in itself is a little difficult too, but even if it is possible, what measurement are you looking for?
I really dont think that we are given enough info as to when to change the chain as I think my chain is near its life, but according to the indicators on the side its still OK.
So sorry for the very stupid questions and essay, but I am really confused.
Eben
