Left hand link pipe required
Moderator: VTRDark
hawky
Post by hawky »
Looking for left hand std level aftermarket exhaust link pipe (chain side) if anyone has one on its own?
May consider the pair.
Thanks
Re: Left hand link pipe required
you will need t know what diameter your existing link pipe is at the can end, they are not all the same.... what make are your cans?
also the bend shape & length will vary, so getting a pair will help the matching
One of these any good?
[URL=http://s616.photobucket.com/user/V ... .jpg[/img][/url]
Outlet external diameter is 54mm, the end can inlet slips over it.
