All including postage for forum members and I'm open to some haggling. Pics available on request but they're all on ebay too.
Seat - not bad bar two rips at the corners where it meets the tank. One can be sewn up as it's just the seem that's spit. SOLD
Engine cover. £10
2x std exhausts. Both with very light scratches that will polish out. One set has a small dent on the inside of the right hand can but clean link pipes, the other set has no dents but the link pipes need elbow grease to get them back to shiny. £30 each
2x standard shocks. £25 each
2x engine cam covers. Includes vent pipe and bolts. £10 each
Pair of water joints. £5
Rear brake light switch. £5
Rear subframe. Sanded, rust treated, primed and painted in the correct Honda silver with matt lacquer. There are a couple of marks from where the undertray was refitted but that's it. £50
Speed sensor. £20
Left side engine case/alternator cover. Includes stator. £40
Right side engine case/clutch cover. Includes water pump which has rusty blades but turns freely. £70
2x clutch pushrods. £7 each
Std clutch hose. £7
Clutch master cylinder. Seals and piston replaced then never used. £25
Rear brake master cylinder. Seals and piston replaced then never used. £15
Clutch slave cylinder. As above. £20
Also up on ebay is a Mondraker Dune Enduro bike. Quite a few watcher and bids but is a lot of bike for not much cash, unless bidding goes crazy.
Seat, rear subframe and a bunch of other stuff
Moderator: VTRDark
- freeridenick
Re: Seat, rear subframe and a bunch of other stuff
i will take the seat
