This was a project between me and my Dad which, like nearly all of them, has stalled and won't be restarted.
The list below is incomplete, it's just what I can remember. Sorry admin but I'm don't know what he wants for it but wants the lot gone so would be open to a deal I think. I'll find out and update.
Rolling chassis with correct addition of bracing at the rear end, braced rollover bar and welded-in steel floor. Full independent wishbone suspension all round.
Ideal for a Pinto engine but the mount holed haven't bee drilled so would take an alternative. No engine unfortunately. We had one with a ported head but the engine builder has gone dark on us. We had twin Webber 40s but I'm sure if they're with the engine guy or not.
S/S 4 into 1 manifold. New.
Sierra disc rear end: diff, half shafts, new discs and recon calipers
Sierra front half shafts. New vented discs and reconditioned calipers
Complete set of unfitted inner ally panels.
Complete set of bodywork. Glass fibre rearend, mudguards, scuttle, bonnet and nose cone in blue gel coat. Ally side panels which haven't been bent to fit yet.
Top hung pedal box with bias bar master cylinders and reservoirs
Recon steering rack
Steering column
Some fuel line and brake lines
Full custom built loom - new
Ally fuel tank - new
Heater, I think
Some clocks and a bunch of other ancillaries.
Fly screen
Headlights. Again, I think.
There's some work to do to complete but lots of parts are there to get well past rolling chassis stage. Best to get in touch if you're interested and I'll get you in touch with the old man if you want more details
Luego velocity (Lotus 7 replica), incomplete but lots there.
Moderator: VTRDark
- freeridenick
