Both are clean (ish) but the front has had a stud snap in the past. Not on me but some material has been removed which I suspect was to allow access to the bolt.
Front head £50 delivered £40 collected. Valves seat OK but the front exhaust cam is too tight. Valve clearances are OK and I've had the valve lifters out but it's still tight so will need lapping in. I've no idea if it's a different cam from when it was built but the cam caps have matching numbers and the inlet cam is fine.
Rear head £40 posted £30 collected. This one's fine from what I can see. Clearances are OK and valves seat alright.
Anyone want a front and/or rear head?
Moderator: VTRDark
- freeridenick
