Clutch bits - mostly gone
Moderator: VTRDark
Two complete clutches - inners and outers, pressure plate, friction plates etc, bearings and all spacers and rod. One is off the engine completely the other is still has the inner and outer attached but can come of easily.
£30 each delivered.
chris freckle
Re: Clutch bits
Post by chris freckle »
Hi nick, do you still have a clutch available ?
Re: Clutch bits
One off on its way to Chris and Fabio's had the steels from the other one.
Still got a set of friction plates and inner and outer baskets etc.
