hi. ive been having this problem since I got the bike 5 mos ago.
Problem:
1. Low idle at cold start. Engine stalls if I let go of throttle.
2. High idle after engine warms up. RPM shoots up to 1900 after the middle of
the temp guage.
Soution tried to no avail:
1. Adjusted the idle screw.
If I adjust the screw on an already warmed engine (middle of the gauge onward) the idle will go down to 1300. This is ok until the next cold start, by then it will have no idle, engine will stall whenever I let go of throttle & this will continue until it warms (middle of the gauge onward). Its really hard to ride the bike with no idle! So I adjust it to 1300rpm while cold but it will shoot to 1900rpm after it warms.
2. Completely stripped & cleaned the carbs. Jets, needles, float evrything.
Previous owner removed the choke cables & fittings and covered the hole with epoxy.
Eureka! I know this might be the cause but you may know better guys.
3. Installed a hiflo standard filter.
Previous owner installed a DIY foam filter w/c was burned. This was fixed on carb cleaning.
Do I need to get a new carb or is there something i'm missing.
Thanx 4 d replies.
Bike still has ACT, PAIR, stock TPS and jettings.
Its a 98 model.
no idle on cold start, high idle on warm engine
- firestormPH
Re: no idle on cold start, high idle on warm engine
Greetings
Now why would someone epoxy the choke like that
That would be the cause of your problems but it begs the question what else has been done. Make sure you clean the old glue out properly and the choke is working freely as it should.
Id guess the PO broke the plastic choke nut, had the carbs set a bit rich in a warmer climate area and decided he did not need chokes after all...... clearly a tw@ but there you have it.
Or it was as I like to say "slowed down for racing" like idiots that remove the entire air box and just toss on pod air filters, cuz thats how real racers do it.
Or maniacs that remove the return throttle cables and engine shut off switch and wiring ....oh wait, thats me......never mind I said that one
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
- firestormPH
thanks folks!
that b8stard might have broke the fittings and decided to take everything off and put steel epoxy on the hole.
now I have to get a new set of carb. I cant find a way to re install the choke plus he took all the cable out.
glad to have joined here, cheers!
Make sure ideally your replacement carbs come with the choke fittings, and remember to route the choke cables according to the Honda manual (downloadable in the workshop knowledgebase section)
Otherwise... http://ruggedroads.co.uk/epages/00cbb60 ... ducts/7005
OEM plastic one's of these probably broke leading to your woes
