throttles
throttles
iv looked and read and looked some more.....
rc30/rc45.?
R6?.
what is the shortest pull throttle tube anybody is using..of what bikes and what year/model.
iv an RC45 one at the min on one of the bikes but would like something a tad shorter for my wee mittens..
Re: throttles
I'm using 1/4 turn one that I assume was off the RC45. I've also got an HRC 1/6th tube waiting to be fitted. I need longer cables first though.
Re: throttles
now that sounds the biz.... you still running two cables??
Re: throttles
fabiostar wrote: Sun Oct 08, 2017 7:14 pm now that sounds the biz.... you still running two cables??
Yep. I'm not sure what I'll do when I swap.
Re: throttles
iirc i'm running a 1/6th hrc tube, with both cables, I keep thinking about removing the return cable but I never have.
my throttle is nice and snappy, I don't think i'd benefit from a shorter throttle, as it would make it overly sensitive. just my opinion.
Re: throttles
An XM2 domino gives you three ratio discs to play with. But you also need the universal cable set.
It's next on the list for my sp.
Re: throttles
freeridenick wrote: Sun Oct 08, 2017 6:17 pm I'm using 1/4 turn one that I assume was off the RC45. I've also got an HRC 1/6th tube waiting to be fitted. I need longer cables first though.
Unless you don't have standard length throttle cables, the HRC 1/6th tube will fit,
Re: throttles
I thought the standard cables were too short - right on the limit of adjustment.
Re: throttles
No, std ones fit ok if you take the slack out of the adjusters.
But check if you have higher bars fitted, that it doesn't pull on the cables on full fork extension.
Re: throttles
tony.mon wrote: Sun Oct 08, 2017 10:20 pm No, std ones fit ok if you take the slack out of the adjusters.
Am I just being thick, or are you referring to the front brake hoses Tony :?:
Re: throttles
sirch345 wrote: Sun Oct 08, 2017 10:41 pm
They're the main concern but throttle cables could also snag with high bars, depends in how high you go.
A streetfighter with wider and higher bars might need longer cables.
You wouldn't want it revving as you wheelied.....
I've never had an issue as I stick to clipons.
But I do know that a Domino XMS won't fit an SP2 on the std cables, no idea if it'll fit a storm though.
Re: throttles
tony.mon wrote: Sun Oct 08, 2017 10:45 pm
I think I can see where the confusion has come in :lol: you must mean on full steering lock not full fork extension :?:
Re: throttles
freeridenick wrote: Sun Oct 08, 2017 10:15 pm I thought the standard cables were too short - right on the limit of adjustment.
As Tony says they will go but not a lot of adjustment left, but enough. That will be with standard bars (early or later ones) and standard throttle cables,
Re: throttles
sirch345 wrote: Sun Oct 08, 2017 11:06 pm
Cool, that's I have. I'll try that first.
Re: throttles
freeridenick wrote: Sun Oct 08, 2017 11:08 pm
You'll have to slacken the adjuster off fully at the carb end first of all to give the most slack possible, then fine adjust at the throttle end once the HRC tube is fitted,
