Any Auto Electricians on here, Help needed.
cheekykev
Post by cheekykev »
Need a bit of help, I'm thinking of building a custom headlight for my winter project FireStorm, no point going into great detail at this point, but basically my idea is to fit 2 small headlights which will have H4 12v 60/55w bulbs in them, can I just wire these straight into the existing headlamp wiring, or will I have to do some mods to it, If so what will I have to do ?
On the face of it, I'm thinking that the existing wiring, relay, or both will not be up to it to run 2 times H4 12v 60/55w bulbs.
Like what you do
Do what you like
Re: Any Auto Electricians on here, Help needed.
I would use a relay kit from EasterBeaver they would be able to do a version for dual headlight
http://www.easternbeaver.com/Main/Wirin ... _kits.html
cheekykev wrote: Wed Nov 08, 2017 12:25 pm Need a bit of help, I'm thinking of building a custom headlight for my winter project FireStorm, no point going into great detail at this point, but basically my idea is to fit 2 small headlights which will have H4 12v 60/55w bulbs in them, can I just wire these straight into the existing headlamp wiring, or will I have to do some mods to it, If so what will I have to do ?
You've not just contacted me on fleabay about a headlight have you mate?
cheekykev
Post by cheekykev »
freeridenick wrote: Wed Nov 08, 2017 1:22 pm You've not just contacted me on fleabay about a headlight have you mate?
YES
Like what you do
Do what you like
