Stator plugs wanted
Moderator: VTRDark
chris freckle
Stator plugs wanted
Post by chris freckle »
Does anyone have info on the alternator 3 pin plug , as in where I can get one from , both sides if poss. Chris :?:
Re: Stator plugs wanted
E.Marquez
Post by E.Marquez »
chris freckle wrote: Thu Nov 09, 2017 10:17 pm Does anyone have info on the alternator 3 pin plug , as in where I can get one from , both sides if poss. Chris :?:
You want an OEM one or a modern sealed type as used on MOSFET RRs?
Here is the OEM set fro the Stator plug to wiring harness
http://www.cycleterminal.com
YC250-3
and for Wiring harness to stock RR
5P250-312
If you have to replace both sides, why not upgrade to better MOSFET RR and the plugs at the same time.
Here are the ones for the MOSFET RR
http://www.cycleterminal.com/furukawa-qlw-250.html
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
chris freckle
Cheers Guys
I sort of wanted to keep it standard! Clearly that is stupid when I have a set of JE pistons on the way. I will look into what is best in the sealed world I think. :think:
