On the carb balance front I've added a brass fitting to front carb and left the pipes connected. Now, these are Carbtune and have restrictors in them so is that likely to affect fuel valve operation? It seems to work ok at idle but wondered if low vacuum situations and restrictors could be incompatible. I've also plugged the ends with a joiner so technically they are pulling against each other, good or bad idea? On my Commando that's STD with a balance pipe on the intake manifolds.
Would appreciate anyone's thoughts, as dumb as my questions might appear
Btw, happy new year to all.
