Late model clip ons
Moderator: VTRDark
Late model clip ons
Any one out there got a set of late model clip ons lying about that they may want to redistribute....need to ease the discomfort in my achey back and neck ....cheers
Sent from my SM-G930F using Tapatalk
- freeridenick
Re: Late model clip ons
I've got a couple of sets but I don't know if they are early or late. I'll see if I can work it out. I only need one spare set.
Cheersfreeridenick wrote:I've got a couple of sets but I don't know if they are early or late. I'll see if I can work it out. I only need one spare set.
Late ones will be black Nick.freeridenick wrote: ↑Wed Mar 21, 2018 10:47 pm I've got a couple of sets but I don't know if they are early or late. I'll see if I can work it out. I only need one spare set.
- freeridenick
Cheers Mac. Both mine are early ones then. Sorry VTR3545.MacV2 wrote: ↑Thu Mar 22, 2018 6:17 amLate ones will be black Nick.freeridenick wrote: ↑Wed Mar 21, 2018 10:47 pm I've got a couple of sets but I don't know if they are early or late. I'll see if I can work it out. I only need one spare set.
No probs cheers for checkingfreeridenick wrote:Cheers Mac. Both mine are early ones then. Sorry VTR3545.MacV2 wrote: ↑Thu Mar 22, 2018 6:17 amLate ones will be black Nick.freeridenick wrote: ↑Wed Mar 21, 2018 10:47 pm I've got a couple of sets but I don't know if they are early or late. I'll see if I can work it out. I only need one spare set.
get a set of VFR 750 bars, about 30mm higher than standard. or sv650 bars..
Would these be okay with standard brake and clutch hoses as just put new ones on....fabiostar wrote:get a set of VFR 750 bars, about 30mm higher than standard. or sv650 bars..
I'd have said not re the brake lines, definitely not if you have a qa throttle fitted.
Clutch is probably ok, just loosen a routing clamp to get more spare length.
Just try it.
All it'll cost you is another set of brake lines; they're cheap enough and you can sell on your old ones
Just try it.
Stick with the VTR bars. There's a couple of later ones on eBay but they are in Oz and not that cheap (£45 ish each
(. There's one brand new old stock left bar on eBay too and that's in the UK. Shame there's no right to go with it otherwise I would have grabbed them as spares. Actually I could do with a right one as the end of mine has got a chunk missing. Oh well....one day Apex will be coming my way and I really like the idea of Aprillia forks like Al done.
The SV 650 clipons are easy to get hold of and will also improve the riding position, so that would be the quick, cheap and easy option.
Cheers for the advice etc....always rely on yous to keep me right 🖒
I have a set that I got of Mr McQueen of sv ones that have never been fitted if you want?
Don't hassle me
I'll get there at some time
Sorry for late reply and Cheers for the offer but gonna hang on to see if i can get a late spec set.....grumpyfrog wrote:I have a set that I got of Mr McQueen of sv ones that have never been fitted if you want?
Late ones do come up now & then..I recently just bought my 4th set...
The F2 I have came with them, two other sets are on two other Storms & just picked up another set which will go on another one.
Hope that helps...
Hope that helps...
