Box of engine bits...£100
Moderator: VTRDark
Any good to anyone ?
Stripped an engine down for the cases so internals only.
Both heads, crank, rods pistons, gear box, cam covers (F2) clutch, oil pump, & most of the bolts.
There are no main cases or side cases. Or flywheel.
£100 the lot...Pick up only as it weighs a fair bit. Or arrange you own courior...
Comes with free crate... :lol:
Offers taken for separate bits but would rather it went as one lot...
Martinz
Re: Box of engine bits...£100
Post by Martinz »
Any loose cams in there ?
Martinz wrote: Sat Jun 02, 2018 7:26 pm Any loose cams in there ?
No they are still in the heads Alex...Mr Mons might have some loose cams...Unless he junked them all.
I have some cams, which ones are you after?
