I actually have a pair of wingracks, I bought them as spares, stripped them down and resprayed them, I also have two givi arms and brackets as well. but these are rare shorter givi arms, that don't have the ability for a topbox, so they can only be used for side panniers.
I may sell them if anyone's interested.
i just need to sort out a few u bolts for the rear subframe mounting bracket. every part has been taken back to bare metal, acid etch primed, then satin black with satin lacquer.
if anyone's interested give me a shout, just be aware you can't fit a top box using these givi rails, but you can fit the wing rack to a normal set of givi rails if you wanted too.
you will also need to source or make a couple of small brackets to attach the front of the wingrack to the lower mounting point of the exhaust hangers. but that isn't that much of an issue.
ps....i'm going to get told off because this should be in the sales section doh!!!
£70 collection from east London, I will ship at buyers expense.
