haynesjones66 wrote: ↑Fri Aug 17, 2018 4:28 pm
i was thinking that, but because these risers are a bit bulky and a bit further back than i thought, the loom is a bit tight when turning the bars. so i'm cutting a little off the ends of the bars to bring everything a bit closer. the clutch hose will be too close then, even if i spin it up a bit. drilling the headstock for risers does seem to be a better option but it's too late now!
anyone looking to fit straight bars, take note!! these risers are a nice bit of kit but a lot of faff is required to make everything else fit.
You need to be careful by reducing the handlebar length/width, as my banjo bolt on the clutch master cylinder is as close as it will go without touching the fork stanchion with the clutch lever at the angle I wanted, that's without reducing the bar lenght/width.
I know photo's can be deceiving at times, but I don't think your risers bring the bars back any further than mine do, in actual fact I think my bars are back a little further than yours are.
Are far as things being a flaff, I think most modifications are, but once you've succeeded the mod, and you're happy with it, it's well worth the head scratching, blood sweat and tears
If you're referring to the loom on the lefthand side of the bike, I moved mine outside of the fork stanchion as in the photo below:-
