Tank removal, Pipe location.
This referes to pre facelift 19ltr tanks only... I would like to point out that the pics used here are not actually one of my bikes, just ones that I have edited & added the info to...At some stage I will take & add some more pics & even do a new post for the 19ltr tank...
Where possible try doing this without a full tank of fule...Makes it a tad easier to lift... :lol:
Removal of tank.
Take the seat off.
Look for the black wire coming from under the tank, the fule sender,that goes to the bundle of conections just rear of tank, locate the block conector & disconect.
At front of tank 2x bolts...As std these are a 6x28mm but may have been replaced by allen head SS or Ti. Remove the bolts & then lift slightly & remove the 2x top hats if they are there...
Some may have a different way of doing this from this point on but this is how I go about it...
At rear of tank take of the nut on the tank pivot bolt but leave the bolt in place for now.
Lift the front of the tank & either use a tank prop or a bungge to joist...I use a peice of timber as a prop.
Now lets get to removal of pipes...If its your first time take a pic & even use some masking tape to lable the pipes. Once you have done it a few times hopefully you wont need to do this.
Now on the F version the tap will not flow unless a vacume is being pulled so the fule WILL NOT leak out of the petcock when you remove the pipes...However fule still in the pipes may well spill out but its only a pipe full...But some will say turn the tap off...So an 8mm spanner & turn the petcock valve the opposit way to what its sitting at...180* but you must remember to turn it back on to save embarrassing non starting issues...esp when infront of a load of Stormer's at a workshopday...Ahem...XXXX (name witheld... For now.)
Now in the first pic below there is a connector missing of the pipe A the tank vent...It should have a small length of pipe off the stub & a white plastic conector on the main pipe, other than that lets get pipe pulling...
Remove A & B from the tank spigots.
Remove the wire clips from the fule pipes, a simple squeez & pull back, pull fule pipe off spigot on petcock...You will probably get a pipes worth of fule come out now but dont panic thats all you'll get as its just what in the pipe not coming from the petcock. Either have a rag in place or just let it fall out...Just dont be smerkin a tab whilst doing it...
One side will be a lot easier to get off than the other due to space limitations, you may find it easier to do from one side of the bike to the other.
Last pipe to remove is the vac line...please make a mental note of which spigot your taking it from or again take a pic first. Reconecting this wrong will mean the bike wont start...see second pic VLFURP... Vac Line Fek Up Reminder Pic... :lol: :lol:
Now lower the tank back down, remove the tank pivot bolt, note how the black plastic flap fits over the tank mount plate, pick up tank...At this point you'll find out if all pipes & wires have been disconected properly...any resistance & put it back down & check...esp the sender wire !
Pipe conections under tank F only.
VLFURP...Vac Line Fek Up Reminder Pic... :lol: :lol:
If you have a t-peice in the vac line the the free end is for conection to either carb sync (block after use.) or maybe there was/is a scottoiler.
To do the carb sync there should be a take off fitted to the front cylinder as well. This is located on the right hand side of the front cylinder below the carb intake. If it has a tube on it thats your carb sync tube. If there is no tube or take off fitted it will have a allen head bolt in the hole.
Take off as fitted to front cylinder...
The vac tube for the petcock is on the L/H side of the rear cylinder, again just below the carb intake. There should be a take off point there as std unlike the front...
As said the first two pics are not actually my bike but stock photos from somewhere or other but I added the notes...I'll look into doing some new pics & adding them in editing the post as ness in the future...sometime...maybe... :lol: & also doing one for the F2 & onwards bikes...
I'm off to suck some eggs & do a write up on that as well... :lol:
Re: Tank removal, Pipe location.
nice one mac :thumbup:
gabi81
Post by gabi81 »
time well spent mac
Sent from my SM-G950F using Tapatalk
Aha you know what it is black and yellow...black and yellow !!!
I knew you could do it Mac (in under 8 weeks lol) :clap: :clap:
Many thanks mate, nice work :D
mr.hutch
Post by mr.hutch »
Hi Macv2, I see that this is a fairly old post but it's th closest one I've found that looks like I might find an answer to my fuel pipe routing problem. Looking at your first image in this post you've marked one pipe as F2 - exactly where my problem lies. Th chap looking at sorting some other problems (carbs) has discovered th reason for fuel starvation - th line between tank and tap has a terrible kink between F2 and th tank seam. Is this a common problem, has someone possibly fitted 'after market' lines or is there something we're over looking? (mines a 99 model)
mr.hutch wrote: Thu Dec 19, 2024 7:42 pm Hi Macv2, I see that this is a fairly old post but it's th closest one I've found that looks like I might find an answer to my fuel pipe routing problem. Looking at your first image in this post you've marked one pipe as F2 - exactly where my problem lies. Th chap looking at sorting some other problems (carbs) has discovered th reason for fuel starvation - th line between tank and tap has a terrible kink between F2 and th tank seam. Is this a common problem, has someone possibly fitted 'after market' lines or is there something we're over looking? (mines a 99 model)
I wonder if F1 and f2 have been mixed up? Try fitting them the other sides, or reverse f2 front to back.
F2 is pre-formed in that tight 90* bend.
As far as I'm aware these pipes are no longer available to buy as new so it is possible that someone has tried fitting something else & it's just not fit for purpose & has collapsed at the bend.
A photo would help...
I remember our late friend Wicky having this issue from NOT using pre-formed OEM fuel lines, as Mac says, not fit for purpose!
I found his post in the link below ( 8O shocked to see how long ago this was ).
The photo is no longer available unfortunately in his post, but you can still read about the problem there:
https://www.vtr1000.org/phpBB3/viewtopi ... 30#p402330
What about contacting Samco?
They might be able to make you a replacement.
https://samcosport.com/product/vtr-1000 ... torm-sc36/
Not Cheap but would probably hurt less than setting your nuts on fire 8O
