generator output
Flatline
generator output
Post by Flatline »
There's a lot of electrical extras that can be used on a bike
What's the amount of extra load we can draw without too much trouble?
E.Marquez
Re: generator output
Post by E.Marquez »
Flatline wrote: Mon Dec 10, 2018 5:31 pm There's a lot of electrical extras that can be used on a bike
Very little extra
Max the VTR charging system can put out is 23.3 amps or 279.6 watts, but that is at a specific RPM, not across the entire range.
Better to consider it more like 20 amps or 240 watts.
Each bike is a bit different based on set up conditions and each charging system part variance. Best bet is to use an amp meter and measure what your bike uses when running at "normal" use...
You can safely use about 60 additional watts, after that if you don't want to risk drawing off your battery or want to use every available watt for heated gear, lights, GPS, ect...... Test your bike.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
