Coerce Sprocket cover
Moderator: VTRDark
Martinz
Post by Martinz »
So ive finally come to fact that the last remaining unobtainium part for my build is a now unavailable coerce sprocket cover. Has any one any leads to where one might be ?
ooorr willing to give theirs, so I can make a copy for me and anyone else who wants one.
mik_str
Re: Coerce Sprocket cover
Post by mik_str »
jauce.com, they show up fairly regularly
not coerce, but something different none the less...... :thumbup:
https://japan.webike.net/products/9650103.html
Martinz
Post by Martinz »
mik_str wrote: Fri Feb 01, 2019 3:56 am jauce.com, they show up fairly regularly
Ive been checking jauce and nobbin on the regs. No luck such far.
Martinz
Post by Martinz »
agentpineapple wrote: Fri Feb 01, 2019 4:43 am not coerce, but something different none the less...... :thumbup:
Interesting. A bit too much for me :lol:
Why not buy an SP one and have cutouts machined in?
tony.mon wrote: Fri Feb 01, 2019 6:51 pm Why not buy an SP one and have cutouts machined in?
how does that work tony? any pictures?
I've seen a few people cut up std storm sprocket covers and they look bloody good. GLSR springs to mind.... :thumbup:
SP ones are shorter and all except one mounting bolt hole lines up.
The one that doesn't, doesn't matter.
You can cut slots in, preferably with a vertical mill, but drilling a hole then filing works just as well, but it's more work.
Or, to save weight, use one from a varadero cable clutch and fit a cable clutch.
fabiostar wrote: Fri Feb 01, 2019 7:07 pm how does that work tony? any pictures?
Go on you know you need to do something about yours as it's more holier than the Pope. No excuses now you have the lathe.
Martinz
Post by Martinz »
Thanks for the input chaps. However, as per title im after a coerce sprocket cover. Not a cut down F or SP cover. :thumbup:
VTRDark wrote: Sat Feb 02, 2019 5:58 am
:lol: :lol: its already been binned lol
It would appear that amonst the hoard of Storms in the MacCave, there is such a rare thing on one of them...
Now I would be happy to take it off & let you copy it but you'll have to be paitent as a/ I'm a lazy bastid...b/ I need to confirm it is as stated. c/ I would need to hoik all 8 Storms from the cave to get at the spares haul for a spare cover to swap it with... d/ I have other things to do ... e/ it's starting to rain & Id rather not have to put bikes back in cave dripping wet...f/ I cant think of any other excuses... g/ see a/...
Be in the post today...
