Levers
jackson7715
Levers
Post by jackson7715 »
Anyone got any suggestions for an uograded set of levers. Got a yellow storm, but it has standard levers. Want to add a bit of customisation to it. Doesnt have to be an expensive set either. Seen some around on sites for less then £50 a set.
Re: Levers
There's Pazzo or Titax levers - and then there's cheap dodgily made Chinese copies where you risk them causing the font brake to drag, warping disks as a result...
https://www.superhawkforum.com/forums/c ... ers-35283/
Re: Levers
True, but the cheap ones aren't an upgrade, they're a downgrade.
You can't feel much pride for a Lexmark copy..... And the trouble us, you can see them as you ride, unlike their cheap cans.
VTRsquid
Re: Levers
Post by VTRsquid »
The chinese knock offs cat be pretty good, but right to be leery of the quality. One pair might be aircraft grade and good as pazzo except with finer machining, next pair will possibly kill you. And definitely right to take the moral stance.
TaxiDriver
Re: Levers
Post by TaxiDriver »
VTRsquid wrote: Wed Mar 06, 2019 12:59 am The chinese knock offs cat be pretty good, but right to be leery of the quality. One pair might be aircraft grade and good as pazzo except with finer machining, next pair will possibly kill you. And definitely right to take the moral stance.
Be prepared to drill holes in Chinese levers to match the oem ones that should be there...….
Re: Levers
I've had a few sets of chinky levers never had an issue with then but at the end of the day you pays your money...I'd avoid the really cheap ones...cheap isn't always the best option...
Keep an eye out on ebay decent ones do come up now & then...
Re: Levers
No cents, no feeling....
Re: Levers
tony.mon wrote: Wed Mar 06, 2019 2:07 pm No cents, no feeling....
:clap: :clap: :clap: :clap: :lol: :lol: :lol: :lol:
