Right the highways agency has been busy since last year...for a change...
A fair bit of the A2 from M25/A2 interchange has been fully resurfaced, however from about the Esso staion on the far side the new tarmac stops...
There are still a few shallow (still an inch or so deep..) but quite long pot holes mainly along the white lines on the inner lanes...
As you turn off the A2 to join the A228 there is another patch of long shallow potholes along the dotted white line...
As you peel left to head to the dual carriageway there are patches of new tarmac filling the holes that were there last year but there are still a few smaller shallow potholes just as you drop down off the slip road mainly along the chevrons...
Other than that the road from there is fairly hole free... The surface on the rounderbout of dislocated shoulders is still appaling & rutted & the new rear facing 40mph average speed cams start just as you peel off said rounabout...
So you'll be going slow enough to see any dodgy road surfaces...
