Jetting recommendations
VT1000r
Post by VT1000r »
I live at a little I've sea level about 500ft and don't have access to a air/fuel sensor all I have is the good ol butt dyno so I was wondering if anyone has good recommendations I can try my current set up is regular air box with k and n filter, factory pro jet kit with needle at 3rd clip 48 pilots and 185 front 188 rear, and delkelvic mufflers with baffles removed. Oh and also I have JE pistons 11.5 to 1 and fuel screw 2 turns front 2 1/2 in rear, "that last part sounds a little wrong".
Re: Jetting recommendations
What cans?
Sounds a little rich to me, I found smaller pilots and mains were better but then I also had larger inlet valves, an ignition advancer, and gas flowed the heads, so not directly comparable.
What do the plugs show?
VT1000r
Post by VT1000r »
tony.mon wrote: Fri May 31, 2019 9:48 am What cans?
Plugs are black, what size jets are you running and your setup also your elevation and street address? Just kidding about the last part :D . Oh and I'm not sure what kind of delkelvics they are, they have sort of a triangular shape and are longish they look a lot like yoshis.
I found that conversely to common sense I had to fit smaller main jets and pilots when running a tuned engine.
To avoid repeated trips to a dyno I built a real time air/fuel wide band display showing what each cylinder was doing in real time.
I could then tune each section using the stoic ratio.
I agree, those mains are too big. Supporting Tony.mon I'm running Keihin165/168 front/rear but my engine is closer to his than yours. Try going back to stock with the jetting.
