VTR ownership diary by The Lens
thelens
Post by thelens »
well Ive just bought my first accessory ever for the VTR :D
Only a shock sock, but an important part in my view.
I noticed the bike already has a sort of mudflap to protect the rear suspension so I figured a sock would protect it and keep it like new.
Much better than a wheel hugger would do :D
My wants list is growing all the time, so I thought I would use here, to keep a VTR ownership diary of sorts.
Not much of a pimp me ride lol but its a start !
popkat
Re: VTR ownership diary by The Lens
Post by popkat »
Shock sock will trap moisture and rust your spring, if left could cause the shock shaft to corrode too.. Fine if you like them but need taking off regular to dry out and clean under, not easy to remove once fitted on some bikes.. I have to disagree with you in that a hugger works fairly well, and it's easy to reach in to the shock with a rag and give it a wipe. also some huggers protrude below the arm to protect the shock linkage too, these ones are best
thelens
Post by thelens »
popkat wrote: Sun Jun 16, 2019 12:51 pm Shock sock will trap moisture and rust your spring, if left could cause the shock shaft to corrode too.. Fine if you like them but need taking off regular to dry out and clean under, not easy to remove once fitted on some bikes.. I have to disagree with you in that a hugger works fairly well, and it's easy to reach in to the shock with a rag and give it a wipe. also some huggers protrude below the arm to protect the shock linkage too, these ones are best
hmmmm never thought of that. Thanks ! I shall try and keep an eye on it ! :D
+1 for rear wheel hugger
plus brush/wipe over with ACF-30 over the shock esp over winter.
thelens
Post by thelens »
Wicky wrote: Sun Jun 16, 2019 1:36 pm +1 for rear wheel hugger
Ive got ACF 50 earmarked. Never heard of ACF-30 so I shall have a look see... cheers :D
typo - it was meant to be ACF-50 not '30'
thelens
Post by thelens »
Wicky wrote: Sun Jun 16, 2019 3:51 pm typo - it was meant to be ACF-50 not '30'
Kinda glad to hear it.... looked it up and it came up with breast enlarging cream :lol:
thelens wrote: Sun Jun 16, 2019 4:09 pm
lol so now we know what wicky gets upto at the weekend :clap: :clap: :clap:
thelens
Post by thelens »
fabiostar wrote: Tue Jun 18, 2019 8:10 am
Can’t fault him :D :lol:
