Late model fuel tap
VTRsquid
Late model fuel tap
Post by VTRsquid »
Hi guys. Haynes manual does not cover it and i have a workshop manual that covers the wrong models.
How to you disconnect fuel line on models with frame mounted c0ck without recreating exxon valdez?
Pinch the line? Surely there is a proper way?
Re: Late model fuel tap
Yep just 'pinch the lines' I used to use a pair of long nose mole grips but with rubber tube on them to protect the hose.
I've since bought a set of hose clamps...
Like these... https://www.ebay.co.uk/itm/3Pc-Flexible ... SwT2daMVeu
Or drain all the fule out of the tank...
Or find, buy & fit a Valderado fule tap...
VTRsquid
Post by VTRsquid »
Cheers mac. Yeah i just pinched it. Had a set of hosey pinchey things on my wall
Fit some 8mm or over quick disconnects to prevent having the same problem next time.
They're cheap enough.
