rear shock linkage bolts
daz350
Post by daz350 »
Hi i am in the process of replacing my swingarm and shock linkage.Would it be ok to replace linkage nuts and bolts with stainless
xeris
Re: rear shock linkage bolts
Post by xeris »
daz350 wrote: Sun Sep 01, 2019 4:42 pm Hi i am in the process of replacing my swingarm and shock linkage.Would it be ok to replace linkage nuts and bolts with stainless
While stainless might be fine, in such a critical area I would only use OEM or exact equivalent.
~ Mark Twain
they shouldn't need replacing, even if the bearings and inner race buses are shot, the bolts are generally ok
AMCQ46 wrote: Sun Sep 01, 2019 5:20 pm they shouldn't need replacing, even if the bearings and inner race buses are shot, the bolts are generally ok
depends how rusty they are or if you have to cut ther triangle one out !
All sizes & part numbers here...
https://www.ronayers.com/oemparts/a/hon ... k-absorber
