Gravelrash wrote: ↑Sun Oct 13, 2019 3:50 pm
I was given front and rear stands by the guy I bought my VTR off but with no grab rail to steady the bike I confess I worry about using them. Anyone got a tip for where to best hold the bike during this balancing act?
Firstly use something under the side stand to level the bike up a bit.
I use a 5'' square of 15mm MDF.
Secondly take the seat off & use the rear part of the subframe to hold on to.
Get the cups under the swing arm, the left side will be incontact, the right side will be just out of touching, as you push down on the stand the bike will level of & Bob's your mothers brother...
Some will say why its on clamp the front brake on to stop it moving forward.
OLNY try getting the front up with the bike on the rear stand & only on level ground.
When you come to getting it off the stand, on the front hold the righthand clip on & hold the brake on, slowly raise the stand & lower the bike.
On the rear what I do is hold the left clip on, put me foot in front of the padock stands wheel, & pull the bike forward holding the rear footrest hanger, I have the side stand down, & as the bike rolls forward the padock stand filps up...
As of yet I haven't smashed a rear light or shatterd a numberplate...
But you could drape a towel or somthing over the rear to cushion the possible blow.
You could also have the bike in gear, hold the clutch in & once the the padock stand is up & the rear wheel is on the ground let the clutch out & the bike wont roll forward.
Set the bike down on it's side stand & jobs a good'un...
Take a few goes to get confident in doing it but after a few trys it won't seem so daunting...
I think the trick is always have one hand on the bike...
Or better still buy an Abba stand...
As for the hook type, some have drilled the swing arm & fitted bobbins. Others have welded a boss under the swing arm & screwd the bobbin into that. Or you can get bobbin/crash bungs that the bar they bolt on to passes through the spindle as its hollow OK for cleaning but no good if you want to take the wheel out... I also found some that just slot in again OK just for cleaning but no good for wheel removal & although I havent tried it both these type would make it difficult to adjust the chain in situ...
